Hewlett-Packard began manufacturing personal laptop computers in 1993.
3349 Questions View all
Laptop screen won't start up
my laptop, Hp laptop 2000-2b09wm, had gotten wet nothing major. It was working just fine I turned it off after I wiped it and put it on the side. The next day I go to use it the screen won't turn on. I unplugged the charger and took out the battery. Then tried holding the power button for a minute. I plugged in the charger only then pressed the power button I can see my wifi button light up but couldn't hear the fans or computer start up. Why isn't the display screen working please help me.
Add a comment
1 Answer
Chosen Solution
Nikera, this could be caused by the water damage. It is possible that you have a shortened inverter, a shortened LCD or any other part on your logic board. Attach an external monitor and see if that displays anything. If it does, your error is most likely the inverter/display. Download the service manual from here and see if you are up to doing the job. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Nikera will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 222
