Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Is it safe to use with the battery disconnected?
I just bought a new Late 2013 Retina MacBook Pro 13", and I want the battery to remain in top condition as long as it can. So I thought it would be a great idea to disconnect the battery to preserve it when I use it home for a couple days.
Any comments/advices?
Score -1
Add a comment
1 Answer
Chosen Solution
Lets look at it this way:
  • If you dislodge the power cord, what you are working on will be corrupted so the battery is acting like a UPS protecting your work.
  • Your system was designed to be a sealed system
  • The space internally were the connector is located is not big enough for the connector to be disconnected without long term damage with the cover off or on.
  • Constant reconnecting will wear the connection and if you are not careful you could also damage your system if the unit was not fully off (sleep mode) when you altered things.
Bottom line here: leave it alone it was designed to be used this way.
Add a comment
Add your answer
Kiss Zsolt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 366
