Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Can I install a Hybrid HD in optical bay?
I want to replace my optical drive with a Seagate 1 TB hybrid HD.
I'm concerned because of the PATA interface data rate. Which data rate can I expect from this drive in my computer? Could I run Protools projects on it? Could it be better to replace with a pure SSD HD?
Score -1
3 Comments
Thank you very much for your response.
So, besides swapping the system HD and upgrading the RAM to 6 Gb, on the performances side it's better a 400 Firewire disk than a HD in optical bay, isn't it?
I'm thinking about the upgrades you suggested to me….
by
External FireWire 800 case is best. Internally you'll be adding extra heat and besides your new drive (HD or SSHD) can be larger (i.e. 1/2/4 TB) so you really don't need the space internally. What you really need is a HD for backup or if you already have a backup solution then use this drive as a bootable spare drive to hold your OS updates and disk tools to maintain your HD performance (repairing and defragmenting it).
by
Thanks again Dan. Appreciate your precious suggestions. regards.
by
Add a comment
1 Answer
Chosen Solution
Swapping out the optical drive device won't change the I/O of the system board. So the PATA I/O is your I/O limitation.
I would recommend swapping out your current HD for the Seagate SSHD so you gain the full benefit of the drive.
If you still want your older HD you may want to place it into an external FireWire case Vs the optical bay if you want the best performance and usage. Or if you want it internally place it into the PATA to SATA optical drive carrier and replace out your optical drive.
Don't forget your system memory upgrading to 6GB would be ideal (the limit of the system).
Score 1
Add a comment
Add your answer
Lucio Saccone will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 90
