Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone Doesn't Restore Error 16
My iPhone 4 doesn't want to restore.
While restoring the bar goes like 99% complete and then stops and an error window pops up.
There no water damage.
The logic board looks almost new.
I don't know what it could be.
I've tried changing ports, putting in recovery mode, putting in DFU mode.
When i plug in the iPhone, it always goes to this screen:
Score 5
8 Comments
Have you tried a different computer, different cable?
by
yes, i have tried a different computer and different cable. I even tried that oven reflow thing just now and tried to restore again. the same error came up..
by
Why and how did you try to reflow the board?
by
I put the logic board in the oven at 350 degrees for 10 minutes... and i let it cool for 20 minutes.
After that i put the iphone back together but problem still persists. I'm telling you the logic board looks brand new. i'll post pictures right now.
by
i have two mainboards with the same issue! Please let me know if you found a solution
by
Show 3 more comments
Add a comment
Most Helpful Answer
IT IS THE Baseband Processor IC Chip
Score 1
Add a comment
Usually once you get that error the board is done unless you get someone that knows how to repair the board "ic repair". What needs to be repaired is under the cap near the battery connector. I have only gotten one phone working after i got that error and it took me trying at least 10 different methods. Here is something I found that worked for others with this issue:
Hope this helps... Error code 16 is a hardware issue/fault
With my particular phone it was a battery fault I didn't have to buy any new parts or anything I just disconnected and reconnected the battery a number of times.
Iv done this 3 times now I have to do it every time I upgrade the firmware and it's worked every time for me.
So here's some steps to follow
1. Remove the back with a small cross point screw driver
2. Remove the screw that holds the battery connector
3. pop the battery connector off and and reconnect it
4. Connect device to computer
5. Place the device in DFU mode
6. Once in DFU mode carry out a restore
You may have to repeat these steps a number of times but if your issue is the same as mine then it will work its worked twice for me this week with the iOS 7 and ios7 update firmware
2 Comments:
i've tried the battery thing it didn't work. is there any way i can check for errors on the motherboard myself ...
by
No there is not a way to check yourself. iTunes is the only way you can find out there is an error on the MB. Then when you get the error it is so vague you can not pinpoint what the issue is. you just might be out of luck. Have you tried any 3rd party software to restore your phone yet?
by
Add a comment
try restoring from icloud on the phone .do not restore from a pc..thats the answer jj
1 Comment:
it wont let me on the phone
by
Add a comment
i have also same problem but i repace the battery ang usb port is sorry no picture
Add a comment
see if this method works for you guys,
if your restoring process stop at 95%,click and hold power and home button for 2sec and repeat it 4-5 times.
3 Comments:
Ill try that now thanks!
by
Actually xD it just restored I recomend not moving the phone or anything while restoring
by
please tell me when to hold powee and home button , when he stuck ?
by
Add a comment
dear sir
I have 2 iphone 4 also problem error 16 can u help me iam verry said
please help me what i do (((((((((THANKS))))))))) In Advance
1 Comment:
used DCPS 5A bro i tested and face like that !
by
Add a comment
Add your answer
Denise Lopez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 20,634
