Repair guides for the MacBook.
3787 Questions View all
A1181 No Backlight & no power on Pin 4 backlight connector
I have a Macbook A1181 with the 820-2279-A Logic Board and 13" display that the backlight is not working.
I know the display works being when its on, you can see an image on the screen but its very dark to see.
I purchased a replacement inverter thinking that was the problem but still no backlight. My only issue is could it be that the replacement inverter I got is bad as well? I really don’t know how I can test if the inverter is exactly supplying voltage on the other end that the LCD plugs into? Being if I plug a volt meter into that end won’t it fry my volt meter?
I was able to finally figure out a way to test to see if the backlight was bad on the Macbook screen itself. After plugging that into another spare laptop, it does light up. I did try plugging a spare screen monitor into the Macbook and it doesn't light up.
I tested the 4 wires coming from the backlight connector on the logic board and I do get the same reading from the board to the other end of the connector which confirms the backlight harness is good. However I saw a post with what voltage I am supposed to see from the Backlight connector.
pin1 (right side): 12V,
pin2 : ground,
pin3: 5V,
pin4 (left side): 3.3V.
While the laptop is running with a volt meter I do not get any voltage from Pin 4 which is supposed to be 3.3v? Is this the reason why I am not getting any backlight to my screen? Is there a resister or something causing this not to supply voltage to this pin causing the backlight not to work? Any tips on what I should check/replace would be greatly appreciated.
Score 3
Add a comment
Most Helpful Answer
Michael Dougherty, pin 4 is coming from the backlight power management. Check the AND gate U9053 as well as coil L9001. Ultimately, it does sound like a bad inverter, and you better not test it with a conventional multimeter due to the high AC voltage.. If you need to identify the components, post an image of your logic board with your question. Hope this helps, good luck.
Score 3
Add a comment
Hi,
1 pin 12.6V
2 pin 0 V
3 pin 5 V
4pin 3.3 V
Is correct?
My screen blink on start up and keep black, if i remove and input conector from motherboard to inverter , blink again and black screen .
I already changed inverter and flat, just not change inverter cable.
Some one could help me, i don’t have more any ideas
Add a comment
Add your answer
Michael Dougherty will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,736
