The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Touchscreen works, but display is dark. Can I fix it?
After the phone fell from my pocket onto a tile floor, the display went black. For a while I could see a few thin, faint horizontal lines at the bottom of the display, but then those went dark, too.
The touchscreen still works. I can answer calls (if I swipe in the right part of the screen), take pictures (if I can hit the camera icon blind), and so on.
I used the disassembly guide to locate the display data cable. I pried it off gently, then snapped it back on and reassembled the phone, but no dice - it acts exactly the same. What else could be the problem? Is it fixable?
Score 2
Add a comment
Most Helpful Answer
LCD is broken.
Samsung galaxy S3 LCD screen and touch screen, they are one and the same.
You need change it. Probably $ 132.
Score 1
Add a comment
Yup, as Chloe said, LCD was damaged, you can replace the LCD+touchscreen+frame, which can make your repair much easier and less risky, S3 screen replacement is not that expensive now, it costs less than $80, check it out: http://www.etradesupply.com/oem-samsung-...
Add a comment
Add your answer
Andrea Reese Hurst will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 20
All Time: 1,041
