Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Broke Off 1 Pin of Cell Antenna = Bad Reception. Fix?
Hey guys,
I snapped off one of the feet of the antenna bridge (the one on the right) in an iPhone 4 and now I only get pretty bad reception from the device. Is there any way to fix this or do I just have to get a new cellular antenna?
Any help is appreciated.
Thanks,
V
Score -1
Add a comment
Most Helpful Answer
You can also get a replacement antenna for less than $10 and it should fix the low reception. On a level of 1-10 of difficulty to replace, 1 being easiest 10 being hardest, it is a 1.
Score 1
1 Comment:
Already ordered one, took mine out again to clean it today and it's fairly simple. Thanks again.
by
Add a comment
Hi,
before to change the antenna try to clean its contact as the grease of the skin can cause poor signal.
Beppe
1 Comment:
Thanks for the tip, after cleaning the feet with windex the reception did improve but it's still not up to the original strength. I guess I will have to replace the antenna after all.
Thanks again!
by
Add a comment
Add your answer
Vandal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 242
