2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
MacBook screen won't turn on
I have a 15" MacBook that I would like to fix, the computer will power up but the screen stays black, I have read about starting in safe mode resetting the pram, checking for the ram to become unseated all have been a addressed to no success, I also read about a possible bad logic board, I can't read my model number anymore but it is the 2.2ghz, core 2 duo, 2gb/128mb vram120gb emc 2136 serial number w8740q9ex91. I would like to fix te computer but need more guidance as to approach.
The computer is powering up but the screen will not light up, I messed with the computer a few months ago and as long as it stayed on, didn't sleep or die it was functional
All help is appreciated
2 Comments
Start off by attaching an external monitor and see what it displays.
by
I have the same issue , is it ok if you connect
To an external monitor?
by
Add a comment
Chosen Solution
start off by doing what Apple suggest:"Power, but No Video (Computer begins to power up, the fans and hard drive spin, the Caps Lock key lights up when pressed, but there is no startup chime or video.)
Note: Examine the display carefully. An image may be barely present on the screen, but with no backlight clearly illuminating the image. In this case, the system is working properly except for the backlight. Use the Display: Dim Video troubleshooting section to resolve this issue.
1. Reset the power manager (SMC).
2. Try connecting an external display to check for intact video signal. If external video appears, check the system for any pending software or firmware updates and update accordingly.
3. Verify that the LVDS cable connection is properly seated to its connector on the logic board and that the cables are not damaged.
4. Remove the display housing and check that the flex connection is properly inserted, aligned and seated in its connector on the panel. Misalignment can cause multiple video issues. During insertion, the connector should be perfectly straight, not at an angle, and the connector should slide into its mate in a flat position, parallel to the LCD panel, not obliquely.
5. Replace the display assembly.
6. Check all cable and flex connections to the logic board. Try restarting.
7. Replace the logic board.
Step 7. is the one I would wait with. Now here comes the important part. Are you capable of measuring the backlight fuse as well as the WLED driver to see if those function. Those are the parts that are responsible in part for the backlight. Hope this helps, good luck.
Score 1
Add a comment
I loved the one that I had like this, in my humble opinion, I think that either a cable is loose or unconnected. The other thing that could have happened is that the back light could have burnt out.
Hope this helps,
John H. Laney
Add a comment
Add your answer
Cory will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 6,463
