The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
35 Questions View all
Cracked casing, Power Button overly sensitive, random reboot
My TF300 has two issues- the power button issue is the really big problem. Anytime I touch the AREA where the power button is (i.e. the top left of the screen) it decides to turn off or reboot. I am guessing this means the switch itself needs replacing or something. Is that a DIY repair for someone who has done a bit of laptop repair? I have replaced my own hard drive and upgraded RAM- and have been willing to try more complicated things but haven't had the need.
The cracked casing (or backing) may also be contributing to it- you can see cracks especially where the tablet connects to the dock (poor design, IMO). If it isn't practical to replace the backing, anyone have advice to shore it up?
Score -1
Add a comment
Most Helpful Answer
Mine did that. I found that the tape that holds the on/off switch contact moved just a little bit. Pop the back off and look at the tape with a little copper disk at the switch and make sure it is aligned properly. Good luck
Score 2
2 Comments:
Thanks!!! Your fix worked for me too! Mine is now working for the first time in about 4 months.
by
Thanks !!! That simple fix worked for me as well, driving me crazy and let it sit for almost a year before I found this fix!
by
Add a comment
I had the same problem with my tablet.
Bought at Amazon.fr (dec 2012), the problem with the power button and random reboots appeared after 9 months...
I took photos to help repair.
The little copper disk under the tape must be recentered.
1. the problem
https://pbs.twimg.com/media/BSWouQaCQAAF...
2. the fix
https://pbs.twimg.com/media/BSW5kUGCcAEX...
Score 2
Add a comment
Add your answer
Lindsay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 4,457
