Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
I have a water damaged iPod Touch to fix, please read!
This Ipod will turn on except the screen is so dim you can barley tell it is on, and yes the brightness is all the way up. Do I just need to replace the screen? Thanks for any feedback!
~Oscar Garcia
Score -1
Add a comment
1 Answer
Chosen Solution
Oscar Garcia, it is the LCD to contains to backlight, but the coil and the IC to supply the power to the backlight are on the logic board. You need to make sure that you cleaned the board as well as all the connectors properly. Use 90%+ isopropyl alcohol and a soft brush for that. Replace your battery, reassemble your iPod and re-evaluate. If it is still dim, I would start by replacing the display assembly and work my way up from there. Hope this helps, good luck.
Score 1
3 Comments:
Thanks that really helps!
~Oscar Garcia
by
Also if you have time it would be helpful if you took a look at my ifixit meta question!
~Oscar Garcia
by
Thank you for accepting my answer. Just looked at your great question on Meta. I am going to give you a detailed answer as soon as I have a bit of time. Got to work tomorrow so I'll need a bit of time. You'll get a few answers from others and pay good attention to what people are telling you. The upmost important thing, keep on learning everyday something new and different :-)
by
Add a comment
Add your answer
Oscar Garcia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 87
