Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
water damage, turn on sometime then off?
hi, I water damage my Iphone 4, dismantle the whole thing change battery, and once plug turns on everything works, but the wi-fi isn't, as far as I can see, then after few minutes, goes off altogether, unplug then plug again the same, when is working if unplug goes off completely,
thanks to anyone who can help me with this.
yoel.
Score -1
Add a comment
1 Answer
Chosen Solution
yoel santos, I suggest that you no longer try to turn it on or try to charge it. Disassemble it using this guide and properly clean it. Use this guide to clean it. It was written for a 3G but all the points are still valid for your phone as well. Always check your board for any missing, burned or otherwise damaged looking components. After that replace the battery, reassemble your phone and re-evaluate for any problems. Make sure that you have a new battery for sure and that it is connected properly. To get the WiFi working again, may require a reflow of the IC. Hope this helps, good luck.
iPhone 4 Logic Board Image
Guide
iPhone 4 Logic Board Replacement
Difficulty:
Difficult
30 minutes - 2 hours
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Score 1
Add a comment
Add your answer
yoel santos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 78
