Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Questions View all
weird screen glitches and freezes, can't be force-quit.
Hi, is it OK to follow up or should I open a new thread?
My parents have an 2006 iMac (model name: iMac4,1) Intel Core Duo, 2 Ghz. that suffers from weird screen glitches and freezes, that can't be force-quit.
Accoording to the system profile (sorry, it's in Dutch):
Modelnaam: iMac
Modelaanduiding: iMac4,1
Processornaam: Intel Core Duo
Processorsnelheid: 2 GHz
Aantal processors: 1
Totaal aantal cores: 2
L2-cache: 2 MB
Geheugen: 2 GB
Bussnelheid: 667 MHz
Opstart-ROM-versie: IM41.0055.B08
Graphics:
ATI Radeon X1600:
Chipsetmodel: ATY,RadeonX1600
Type: GPU
Bus: PCIe
Breedte PCIe-baan: x16
VRAM (totaal): 256 MB
Fabrikant: ATI (0x1002)
Apparaatcode: 0x71c5
Revisiecode: 0x0000
Versie EFI-besturingsbestand: 01.00.068
Beeldschermen:
iMac:
Resolutie: 1680 x 1050
Pixeldiepte: 32-bits kleur (ARGB8888)
Hoofdbeeldscherm: Ja
Synchrone weergave: Uit
Online: Ja
Ingebouwd: Ja
Beeldschermconnector:
Status: Geen beeldscherm aangesloten
For now, it seems to happen only when it gets warmer, after a while. Is there something I can repair myself on this?
Score -1
Add a comment
1 Answer
Chosen Solution
Typically video abnormalities (lines, stuck pixels, jagged lines, etc) and freezing seen together are a result of a failed/failing video card. You might boot the Mac in Safe mode (hold Shift while booting, you can let go once you reach the Apple w/ spinning gear) to see if the problem persists, if it does then you can likely rule out a software issue.
The ATI Radeon X1600 cards in these did seem to fail somewhat more frequently than other models but not quite widespread enough for Apple or ATI to initiate a repair extension program. A quick search though shows a video of someone with what sounds like similar symptoms on a similar iMac. video of distorted video on iMac
It's likely a safe bet that the video card is the culprit here. If you can source a replacement (ebay, Powerbookmedic.com, etc) then you can use the guide below to replace it.
Video card replacement in iMac
Good luck!
Score 1
Add a comment
Add your answer
laptopleon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,278
