iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
iPod and possible water damage, no charge or power signal?
I'm not sure if this is related to water damage or not but I have an ipod classic that won't turn on at all. Just a clear blank screen that won't power up from being on a dock or power cord. My mother in-law wore it inside her shirt and sweated with it being there so it might have absorbed the sweat? so possible water damage?
Score -1
Add a comment
1 Answer
Chosen Solution
Possible, but unlikely with this model iPod. There is more physical room than with the other iDevices. Just to make sure, disassemble your iPod using this guide. Then clean all the parts in 90%+ isopropyl alcohol. Once it is cleaned, replace the battery. Make sure you also clean the dock connector on the bottom of the logic board. Look for any bend , broken or corroded pins. Watch out for the battery connector on this model, it does have a tendency of breaking off. Use a L-shaped paperclip to pull straight up on the locking tab to disconnect the battery. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Gabriel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 301
