The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Dropped my phone is salt water, need cost effective ideas
Hi, I dropped my galaxy s 3 in salt water, I did wash it out with fresh water after letting air out the next day , after i had in rice for a week, its been 2 weeks and now it starts up the led lights work the sounds work it vibrates but the screen wont turn on. I am really hoping i wont have to replace the digitizer or whatever its called because its costly so i am hoping you have any ideas on some way i can clean it or fix it before replacing it becomes a option. I have taken a look at the mother board and it isnt very corroded so any suggestions.
Score -1
Add a comment
1 Answer
Chosen Solution
Brianna, "and it isnt very corroded" still means it is corroded. Please remember that rice is a great first aid, but it does not stop corrosion nor does it fix any burned out SMD components. The least I suggest is that you disassemble your phone and clean every part with 90%+ isopropyl alcohol. Use a small brush to do so and do nor forget to clean under all the EMI shields etc. Once cleaned (you may have to do it a couple of times) reassemble your phone, replace the battery and re-evaluate. It is possible that the backlight circuitry has shorted out. In that case, you would have to get a new display. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Brianna will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 350
