Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
My iPod 4gen bottom of screen wont work after digitizer replacement.
i just got my ipod 4th Gen and the digitizer was cracked and wouldn't work so i bought a new one and my cousin(Who is very good at fixing things) put it in for me. it will let me slide to unlock but it wont let me use the space bar or any of the apps at the bottom of the screen. please help me? It was a birthday present and i dont want to have to throw it away although i have a feeling i might end up having to do that!
Add a comment
Chosen Solution
Shari, it is my experience that if the digitizer does not work on a specific area, the digitizer has failed. So if it is reactive on most areas, except on a particular one, this may be caused by a bad digitizer. Contact the vendor and replace it once more. Of course you also want to try a reset and restore, but most likely this is a bad part. Hope this helps, good luck.
Score 1
2 Comments:
Could It be i need a new screen?
by
It is the digitizer that controls your touch, so that is where I would start.
by
Add a comment
"You are tonight, bonebag." The reflection smirked, "But I'll give you credit -- usually, a !&^&^-eating jock like you don't start fighting back until like 5 AM and $@$*. You got yourself a strong head perfect busty babes
"What are you even talking about? A-AhhHHH!" Blake gives a pathetic yelp as he looks down at his shirt -- both of his nipples are pushing forward under his shirt, but they feel like they're being pinched like purple nurples! He looks up to the mirror and sees his reflection has both nipples being yanked by his hands.
"Here's how it's gonna go down, fleshie." Polter says in the mirror, "Turns out, you're too strong for me to hold your brain for more than a couple hours. So if I can't control your mind, I just gotta manage you carefully." He lets go his nipples, letting Blake huff and groan in relief, rubbing his stinging nubs a bit.
"But what the &&^&?! I thought I got rid of you!"
"Pffff. What, with the cross gag? Think Jesus on a stick was gonna &&^& me off?" Polter scoffed, "I ain't a demon, jackass! I'm a &&^&^$ poltergeist! Case you're a bigger dumbfuck than you look, there IS a difference."
Add a comment
Add your answer
Shari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 253
