regarding replacing I/O board?
I'm assuming this is what I need to do with my macbook. For years the power light fades and pulsates from green to amber, not charging the battery and then magically starts working again within a couple hours. It always worked when I took it to the Apple store. Over the last year, it has become more common. A couple weeks ago, it was down for 15 hours and magically lit up sometime overnight. It went down again 2 days ago and won't come back up. I took it apart last night to see if the connector looked loose, but it didn't. I read someone's post about how they replaced their I/O board and it worked for a short time and then stopped working again.
Before I spend $100 buying a new board, is there any reason theirs would work and then stop, other than a faulty board? I don't remember if they said where they bought it but I see one for sale on this site with a 6 month warranty.
I would rather put the money towards a new computer, but I can't afford to update my Adobe software right now. And if I can't use it, I can't make any money.
Thanks for any comments, suggestions or warnings.
Score -1
Add a comment
1 Answer
Chosen Solution
The first thing I would do is see if the simple stuff fixes your problem:
- Clean the MagSafe connectors system and charger with Isopropyl alcohol with a cotton swab.
- You should try a second charger to be sure here.
- Open the system up and look for any water damage. You may want to go though the process of taking the Left I/O board out (Fair warning here its a bit of work) looking on the underside of any damage. iFixIt guide Left I/O Board
Add a comment
Add your answer
Kari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 110
