Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
iPhone doesn´t charge even after repair it
My iphone 4 was charging very slow (10% by hour) and it didn't detect that its plugged, so I thought "May be the battery was dead", so I replace it and it didn't change. After that I decided that the dock connector is the problem, so i replaced it but the problem persist.
Maybe something on the logic board is damaged?
Score -1
3 Comments
Like Vincent Monteil says, try a different cable as well as an AC adapter and see if that makes a difference.
by
I've tried with lots of cables even with a 30-pin to RCA and it doesn't stream video or audio
by
Have you checked the charging coil and components?
by
Add a comment
1 Answer
Chosen Solution
Hi jim !
In fact, people often think that the problem comes from a dysfunctional iPhone part. Actually, the problem could absolutely be your connexion cable or AC Adapter ! Do you use an official one ? Is it old ? I know that it can seem to be nothing but even if they are more expensive, you shall prefer using official new one. Your iPhone is mabe ok !
Let us know how it goes,
Hoping to have helped you,
Vincent
Score 1
Add a comment
Add your answer
jimenezser will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 11
All Time: 203
