First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
Locate home button connector on circuit board,
I have the ipad 4 all prepped for assembly. The home button ribbon was damaged, ordered and received replacement. I can not locate the home button ribbon connection on the circuit board. The board has the connector for the wifi, the plug in power connector for the charger, and the 6 pin connector. click on images to enlarge......
Score -1
1 Comment
wantobea7, use this guide Adding images to an existing answer to add the images.
by
Add a comment
1 Answer
Chosen Solution
Hi !
Here is a full guide explaining to you how to replace the home button on an iPad 4.
Hoping to have helped you !
Vincent
iPad Wi-Fi Home Button Switch Replacement
Score 1
1 Comment:
This does not match my board at all can I upload a photo and you can show where the ribbon connects?
by
Add a comment
Add your answer
wantobea7 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 459
