CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
421 Questions View all
iPhone 4 lock button broken & black screen
About 2 months ago I got a color change on my iphone 4, it was working perfectly. Then probably a month later my lock/sleep button broke. It's unresponsive it's kind of jammed not sure how it happened. Two days ago I woke up and my screen was all black kind of dark blue but I can still hear it ringing & receiving texts. I can't reset my phone because the lock button is jammed so I'm not sure what to do.
Add a comment
Chosen Solution
Let the battery go dead, plug it in and hopefully the lcd will work, then turn on your assistive touch so you have an option to use your sleep button, or you could replace your sleep button flex,,by the way a hard reset may not fix your screen, you should check your lcd connections, and you may need a replacement screen , good luck.
Score 1
Add a comment
I an having the same problem. How will I know when the phone is dead when I cant see the battery percentage?
Add a comment
Add your answer
Ameerah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,080
