Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
MAC OSX Lion Encryption.
I want to upgrade the Ram and put in an SSD Along with swapping out original drive for Optical drive. My main question really relates to Apples Encryption that I put on. How much of a pain in the butt is it to move the O/S with that encryption engaged?
2 Comments
Can you be more specific in regards to the encryption? Are you using FileVault, a firmware Password, third party tool, etc?
by
It's Apple's File Vault Encryption
by
Add a comment
1 Answer
Chosen Solution
To start with you are not moving the OS, you'll be installing a fresh copy on the SSD from your Lion or Mountain Lion installer.
As long as you boot up under your FileVault drive using your user account the files were saved under you can then copy them over to your SSD.
As the SSD does not have FileVault running the files copied over will no longer be encrypted. Think of it this way, if you plug in a plain old USB thumb drive and copy a file to it any then tried accessing it on a different system you would not have any problems access the file (not protected), this is no different.
The rub here is when you flip the boot drive over to the SSD. Now your FileVault drive won't be accessible as the key chain on it won't have the needed keys. Here's a good writeup Apple TN on FileVault and the one MacWorld writeup
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 95
