Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
My screen won't come on after replacing the proximity sensor
I replaced the proximity sensor in an iphone 4 and now the screen won't come on. The phone does come on because when I plug it in it will vibrate. I installed another screen I had and even tried putting the old sensor back in but the screen won't come back on. I've also tried rebooting it. Is there something on the board that I could have damaged?
Score -1
Add a comment
Chosen Solution
Check that you haven't blown the backlight you can do this by holding the phone over a light and you should see the images on the phone very faintly.. Or check you haven't damaged the connectors on the motherboard
Add a comment
try hard reset (home button + power button for 15 seconds), then restore, view board using a microscope to see if any iC are damaged, test screen on another phone, buy a new screen or board. If your in New Zealand you can buy replacement parts here Synced Repairs.
Add a comment
Add your answer
beckygettman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 111
