Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
Vibration is dead, tap trick didnt work
vibration is dead.
I tried the tap behind the back trick, no result.
Can it be anything else than the vibrator? How do I identify which piece is broken?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Either you need to clean the prong under the vibrate motor or the motor is busted or the flex cable is faulty. Start with a new motor then you will no
Add a comment
Add your answer
Guillaume Charron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 113
