Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
screen doesn't go black when talking
Hello,
recently replaced the front glass... the little sensor that makes the screen go black while you're holding it to your ear... i beleive its missing. do you sell it?
thank you
ilya
Score 1
Add a comment
Most Helpful Answer
you can also cut it in half and only cover the proximity sensor (right one).
if you dim the ambilight sensor (left one) the automatic screen brightness won't work properly
Score 2
Add a comment
This has nothing to do with the connectors when you change the screen the little spacer can go missing that's over the proximity sensor... I use the insulating tape method were you cover it over the two sensors and then with a pin make a tiny hole were both sensors are placed this should sort it out..
Score 1
Add a comment
I had the same problem, and I bought new LCD screen (because that one had 3 yellow dots) and that fixed my problem without changing proximity sensor.
Maybe try to connect again the same LCD (connectors)
I hope that it is going to work for you :)
Add a comment
Add your answer
ilya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,246
