Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
855 Questions View all
Troy-bilt 17.5 briggs & stratton motor is smoking.Oil level is correct
Smoke is slightly dark and engine hesitates.
Score -1
Add a comment
1 Answer
Most Helpful Answer
rufusfwoodalljr, depending on exactly which B&S engine this is. It could very well be an issue with the carb of having to rich of a mixture. Change the gas with some fresh gas, clean your air filter and change your plugs and try to adjust the idle mix screw. If you can give us the serial and model number of your engine, we might be able to give you a more concrete answer. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
rufusfwoodalljr will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 178
