Pulled off fan connection.
After spending a whole day replacing the keyboard it looks like i pulled off the fan connecter from the mother board.Can i fix it or do i need a pro to fix it.Thanks.
Also, that depends on you. Only you will know if you have the tools and the knowledge to solder it back on to the logic board. You can not glue the connector, so if you still have enough of the contacts left you could solder it. It would help if you post an image with your question so we can give you an exact answer. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 79
