Repair and disassembly guides for AirPort routers including the Airport Base Station, Airport Extreme, and Airport Express. The Airport line was introduced in July 1999 and discontinued in April 2018.
96 Questions View all
Airport Express External Antenna?
I recently bought an Airport Express and shortly thereafter, got the idea to mod it with a bigger antenna. There's really nothing online showing that sort of mod but many with the extreme!
How can I add an external antenna to the Express?
I saw one, I believe it was by Quickertek. Although, it wasn't much cheaper their way than buying the Extreme!
Help, please!
1 Comment
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
The contemplation of an inny or an outy antenna ;-}
The Airport Express, Airport Extreme or Time Machine where never intended to be a super long distance AP's, others offer these.
The other aspect here is the Express unit is heat welded so you end up making a mess of the case. The Extreme or Time Machine units can at least be opened.
Score 1
2 Comments:
Thanks Dan,
I already have it opened though, I had already decided to take on this project when I posted the question. And as I said before , I saw one modded with an antenna mounted through the top, If I were to do the same on my own, where would I need to make the connection to the logic board? Would I have to remove the original antennae?
by
I wasn't able to add pics but I may have found the answer, it looks like there is a U.FL post just below both of the 2 antennae. So, a couple of pigtails with SMA connectors at the opposite ends should do the trick, I finally learned about that (U.FL) type of connector just yesterday, a D-link router was being modded!
Thank you!
Shaun
by
Add a comment
Add your answer
Shaun will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 4,149
