Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1957 Questions View all
iPhone 3GS vibrator do not work,
Hi, I have an iphone 3gs 32 gb, i replaced the back housing and the glass screen, everything works but the vibrator, it works fine from setting also I removed the motherboard and installed anotherone and it works just fine. Obvious is a mother board problem. How can I fix it?
Comments:
sergio cortez, what exactly do you mean when you say "it works fine from setting " Does that mean you had the vibrator working?
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Hi sergio,
For sure, it could be a motherboard problem. However, I would first check on the two pads of the motherboard on which the two vibrator pins are pushed when the motherboard is secured.
Use this teardown guide and take a closer look at step 12. You find the two pads for the vibrator motor to the right of the notch at the buttom of the picture. Is there anything unusual or strange?
Steffen
Score 2
Add a comment
Add your answer
sergio cortez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
