A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
61 Questions View all
Digitizer cable won't lock inl
I replaced the battery in my HP TP but when try to re-assemble the unit, I can't get the black lock tabs on the digitizer ribbon cable to lock down. Even without the cable in place the black hinges won't lock in place.
Add a comment
1 Answer
Chosen Solution
Hi Lew,
Take a look at this guide, step 9 (particularly picture #2).
First and as far as I can see, the ribbon cables have notches on both sides and have relatively long contact blades. So, first carefully push them into the connector in a 30 degree angle. When you finally feel a resistance, they are "docked" in the connector. Now, before you flip down the flaps be sure that each cable lies flat on the contact bar and is fixed on both sides through the notches (use the image metadata of picture 2 to enlarge it so that you can see more detailed). Each ribbon cable has to lie "in" these notches.
I hope this works. But in case not, I would try to lock the flaps without the ribbon cables and see if they still work. Always push these laps down all along their length, e.g. through a flat metal spudger, pencil or short ruler.
Steffen
Score 1
Add a comment
Add your answer
Lew Murray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 314
