Released in 2007, identified by model number WD-57734.
16 Questions View all
Projection shows black & white flakes?
Projection image shows flakes when viewing. Flakes increase every on/off cycle. Almost unviewable. Any suggestions?
Score -1
2 Comments
Thank you, very helpful. Once i gained acces from side panel only thig left was projection. A relief to know
by
You are welcome and hopefully you will get it fixed.
by
Add a comment
1 Answer
Chosen Solution
PWILLIAMS, sounds like your DLP chip is failing. It literally has thousands of tiny mirrors on it and each "flake " you see is a mirror failing. This is a known problem for this model and Mitsubishi had at one time a program, to cover 1/2 half of the repair cost. You may want to contact them on here. If not, then use this guide to replace this chip. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
PWILLIAMS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 474
