An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 Questions View all
Why won't my GBA SP charge?
So here's my issue. Whenever I try to charge the device, the indicator light turns on for a couple seconds, then turns back off. I've noticed that sometimes if I bend the charging cable a certain way, it might start charging. But, it will not keep charging if I let go of it. Any ideas?
Add a comment
Chosen Solution
Jesse M, sounds to me like you already figured it out:-) "if I bend the charging cable a certain way, it might start charging. " I would start with a new charger and a new battery. If that does not work, I would then replace the charging jack. Hope this helps, good luck
Score 3
Add a comment
probably the circuit board
Add a comment
Add your answer
Jesse M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 5,394
