Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Questions View all
Question Closed
lcd compatibility question PLEASE HELP!
This other question still hasn't been answered and was up most of the day. I REALLY need some help soon if possible as the ebay seller is holding the screen pending an answer to this question ! Is there a list of compatible lcds? does a1304 work?
"I found some anecdotal evidence online that the a1369 and a1466 (1366?) mbair lcds are interchangeable. I found a newer 13" mbair lcd a1304 for cheap so I bought it without checking compatibility... is there a site or list somewhere useful for finding compatible lcds for each model laptop? I can probably use an adapter but the only good adapter sites I've found are all in Chinese! please help.. ty."
1 Comment
yay finally some helpful comments. see them and contribute here please! Is there a list of compatible lcds? does a1304 work?
by
Add a comment
1 Answer
Chosen Solution
Looks like the panel for the A1304 has the part number 661-5069 and is compatible with the following models:
MacBook 13.3" 1.83GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 1.83GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2006
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.0GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.0GHz Core Duo (A1181) - Mid 2006
MacBook 13.3" 2.13GHz Core 2 Duo (A1181) - Early 2009
MacBook 13.3" 2.16GHz Core 2 Duo (A1181) - Mid 2007
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Early 2008
MacBook 13.3" 2.1GHz Core 2 Duo (A1181) - Late 2008
MacBook 13.3" 2.2GHz Core 2 Duo (A1181) - Late 2007
MacBook 13.3" 2.4GHz Core 2 Duo (A1181) - Early 2008 You did not quite tell us which MBA you have but it looks like this may not work for you. Information is from here
Score 1
2 Comments:
thanks for this info. do you know of any adapter sites that are in English.? i have seen some pretty amazing things in Chinese like taking a $30 generic laptop lcd panel and replacing $100 screen with them by clever adapter usage. i would imagine just about every display is compatible with another of the same size and total pixels or even pixel mismatch and still work 90% of the time kind of stuff. I am not above soldering and wiring my own adapter but for this I will need the schematics to match each wire correctly and of course pre-manufactured couplers for the connections at each end.
by
It would help if you supply the model number of both panels.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 218
