Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
Why can't I restore my iPhone?
My friend gave me his iPhone that he went swimming with. When i plug it in the screen shows the apple but the back round is gray and there are many lines across the screen that that appear and disappear. i but it in recovery mode and when i try to restore it it says, "Unable to restore iPhone. AN unknown error occurred (1603). is there something wrong with the logic board?
Add a comment
Most Helpful Answer
Restart Your Computer
Simply restarting your Mac or Windows PC may allow you to successfully restore your iPhone.
Try a Different USB Port
Connect iPhone to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built-in to the computer are preferred.
After doing this, attempt to restore your iPhone in iTunes.
Score 3
Add a comment
Hi,
after a little swimming you don't know if there is something damaged or just still wet. So open it up*,put it in a bag with uncooked rice for a couple of days and then try again. If the error stays the same, it looks like an issue with the logic board.
  • Follow the instructions in the repair section to open the iPhone. I think, if you lift the display just a litte, the water can evaporate much easier through that gap.
Score 2
Add a comment
First things first, reinstall iTunes to latest version. Don't rule out that it could be iTunes freaking out and not your iPhone. I have restored them to factory default a few times and if it worked, it worked- i.e. if the phone acts normally (like when they're new without apps) then it worked.
More Reviews: How to restore lost data from iPhone
Add a comment
Are you want to recover your iPhone data?
If you want to recover them, you should depend on the help of iPhone recovery tool.
However, it can help you recover your contacts, notes, photos, movies and more. Trial version is available. You can have a try!
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,252
