Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
Bad battery after strip, cleaned all contacts now even worse! Help?
I replaced the screen, but didn't clean any of the contacts with windex, everything works great but the battery was really bad lasting only 60% what it did before the changeover.
So i stripped it apart and used glassex instead of windex which i assume is the same thing over here in spain using a q tip to clean all contacts.
Now i turn it back on and swear its got even worse!
whats going on? any ideas?
Thank-you!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi Joe,
Not sure what chemicals are in "glassex" but it sounds as though you may have damaged the battery in the phone. Try replacing the battery and see what that does.
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 117
