The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
83 Questions View all
Nintendo DS does not power on.
DS doesnt power on. Orange light comes on when A/C is pluged in and battery charges. When i press power button the green light comes on and then top screen flashes and bottom screen doesnt come on, then the DS turns off. i checked the fuses F1 and F2 and jumped both fuses, but the same thing still happens. Does anyone know how to fix it?
Score 4
Add a comment
Chosen Solution
There is a short in the system. Good chance you have water damage. Check the lower LCD backlight cable and connection. It is the small cable on the right under the larger video cable. The other small one is for the digitizer. There is also a good chance it is the ribbon cable that runs from the motherboard in the lower part to the daughter board in the upper part. Either that cable isn't seated properly or it has been compromised (broke).
Score 2
Add a comment
There is an inductor that is poorly soldered on the board. If your good with a soldering iron it is a very simple fix. Google L2 inductor and you will find the info on how to do it
Score 1
Add a comment
This happened to me as well. If your fuses are okay then you should check if all your connection cables(flex cables,etc.) are all properly connected.
Score 1
Add a comment
how about just get a new battery
Add a comment
Add your answer
Doug will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 9,510
