Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
dealing with stripped female connector.
in reinstalling the main board on an iPhone 4, I stripped the thread hole while trying to get the screw to catch. I'd like not to have to replace the main board. any help is appreciated.
Add a comment
1 Answer
Chosen Solution
Hi jay,
I suppose this particular screw also serves as an electric connection between the thread hole and the motherboard... Here is what you could do:
Take a strip of aluminum foil (according to the length of the screw) and wind it around the thread of the screw. You might wind it even two times, depending on the diameter of the thread hole and how strong it is worn out. Press on this aluminum foil to the screw so that it really gets into the thread of the screw and "sticks on" to it. Then screw it into the hole. It should now hold the motherboard.
If necessary, and when the screw is back in the hole, you might slightly fix it with superglue at one place (dotted), so that it can't move again.
Steffen
Score 2
1 Comment:
thanks for you quick solution. it works.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 135
