Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Battery replacement, code: APN: 616-0431 VPN: GB-S10-374270-01000
Hi,
I have an iPhone 3gs, but my battery broke, for that reason i bought a new one battery. After fixed it, the phone goes very well until the battery consumed, I called, i downloaded apps, i surffing on internet....
With the battery empty i connected to wall charger but the phone don´t charged. I had prove with another charger and cable but the problem persist. I think the reason of all this because i mistake the battery code, so i need an battery with below code:
APN: 616-0431
Thanks for all, and sorry for my english.
Aritz.
aritzbizkarra@hotmail.com
Add a comment
You may want to double check and see if you attached the flex cable good.
Add a comment
I had a problem with my 3gs not charging and not restoring with itunes,after a lot of googling, the battery I had in mine was a 0431,it seems after ios updates greater than 4.xx the problems arise.Apparently there is a logic board on the battery and the new sofware updates cause the problem.It is recommended to upgrade the battery to 616-0435,I have one on order so unable to verify for a few days,fingers crossed the info is good.
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,335
