Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
only 75% of the touch working
hi !
im, new here and i want to fix my iphone 3gs 32GB,
the problem in the iphone that only 75% of the touch works, i mean there some places that the touch work and some places that didnt.
so what should i replace to make it work?
if i'll replace the screen digitizer it'll work fine?
or the problem is much serious?
thanks for your helping ! :)
1 Comment
Alex, this is usually caused by a digitizer that has failed due to a bad circuit. Replacing the digitizer should almost certainly fix this issue. Follow the advise given by Steffen.
by
Add a comment
Chosen Solution
Hi Alex,
I think that there are two possibilities I would check on. Either the cable of the digitizer is not completely snapped into its socket (that is, it got loose) or the digitizer is damaged and needs to be replaced. However, replacing the digitizer is not very difficult.
Here are my recommendations:
First: Open the iPhone and check if the rectangle connector of the digitizer got loose. It is the connector that is labeled with #2; this connector needs to lay even on its socket. For the right cable, see the guide on step 5: iPhone 3GS Display Replacement
If the connector is not loose, then...
Second: I would consider of replacing the digitizer. The good news is that the digitizer of the iPhone 3GS is not glued to the display. This means you can easily separate it from the display by removing the screws. Just follow the guide "Display" of the 3GS here on iFixit. Then order a new one (costs about $10).
I hope I could help you.
Steffen
Score 2
1 Comment:
Thank you very much! :)
by
Add a comment
It's not not worth the time it would take to fix it, you would be better off replacing the phone.
Score -1
1 Comment:
why?
i want to fix it to learn how to fix iphones
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 104
