Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Speaker problem, microphone don't works
Hy, i have a little problem. When i make a call in normal mode ( speaker off ) my microphone works but when i put it on (speaker on) my microhpone wont works. It's a little bit strange. When the speaker is on i can hear what that person said but he can hear me.
Thank you. Sorry for bad english.
Add a comment
1 Answer
Most Helpful Answer
Try to clean the switch for external Speaker, Use a little alcohol isopropyl for to clean.
and try again. However you must test the speaker with a DVOM , normally the resistance for coil speaker will be around 8ohms.Replace if the value is Out under the specification
God bless you
Score 1
1 Comment:
@dr ing ernesto cuadra, where is the switch that needs to be cleaned?
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 203
