red cross stop sign!
i can't access my 120gb classic it either shows the apple symbol or a red cross in a circle
please help
please help
Jason Durkin, here is my answer to a very similar question. "Reason for the big red X is usually a bad hard drive. Try to place the iPod in diagnostic mode, follow the instructions for that from here. you can also try to place the i{Pod in disk mode and see if you can access the harddrive and try to format it. I use a Zif-to-USB adapter to check the drives, you can get those adapters for cheap on places like ebay. Ultimately, I believe that you will need a new hard drive. The guide for the repair is here.The hard drive is available at many places and not a terrible job to change it. There are those that recommend to literally "slap", hitting the iPod hard on the back. Sometimes, it loosens a frozen drive. I prefer to change it and to fix it for sure. Hope this helps, good luck.
didn't fix :( i'll have to replace the hard drive then :(
Yes, sure does look that way.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 886
