Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Question Closed
iPhone 4 is dead,already changed battery
phone connected to ITunes and synced as usual after getting the "connect to ITunes" message. screen is black. I've gotten the SIM card reactivated and was told to power off phone. It's already dead. No response once taken it off charger.
Add a comment
Chosen Solution
Try a hard reset by holding home and power for approx. 10 seconds. If you get no response from the new battery it either has serious issues or it is stuck in recovery. Check that you did not damage the battery connector on the logic board. If the phone worked with the new battery until it died and then did not charge I would suspect it to be a charging port issue.
Add a comment
Most Helpful Answer
I've had a few batteries that have not been dead but are just on the low side and then aren't able to charge, sometimes a kick start from a normal rectangular household battery (the one with both terminals on the top ?9v) connected to the iphone battery- terminal 1 &4 sorts it out. Do this with the battery out of the phone until you have a charge on the multimeter of 5.7 and it should then boot.
I'd also do a quick clean of your dock connector-sometimes there's a bit of fluff or paper on a pin stopping it charging.
If your phone works until the battery dies, or it won't charge then maybe you need to change the dock.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 479
