Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Screen lights up but no picture, phone works but screen is black
Had a broken home button which I've just replaced today but after reassembly the phone appears to be dead when power button is pressed.
It will eventually start and the screen goes from being completely black to a lit up black when home or the power button is pressed, its recognized by iTunes and will sync so all seems to be working fine except the screen.
any ideas what the problem may be?
or have I broken the screen accidentally during repair
Score 4
Add a comment
Most Helpful Answer
try holding the power and home button for 10 seconds to force your phone to restart. if that doesn't fix it then open the phone up again and check under the wifi antenna and make sure the data cable for the display is securely pressed down. if it is then you damaged the display and need to replace it.
Score 3
1 Comment:
Tried holding home and power, still no difference, will fully take apart and reassemble again and see if I have any luck.
Thanks for the reply
by
Add a comment
Sorry to be the one with the bad news Zeruel but your going to need a new front screen assembly, you either flexed your LCD while prying it from the mid frame and damaged it or damaged your LCD-Digitizer ribbon cables assembling it, its real easy to do, good luck.
Score 3
Add a comment
Mitch: I’m having the same issue, despite getting a new screen. Is it possible the screen is faulty/I damaged it during installation? Or could it be the connection point with the rest of the phone?
Add a comment
Add your answer
Zeruel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 79
All Time: 32,335
