Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
iPhone won't switch on and battery replacement doesn't solve problem
About a week ago my iPhone 3GS died and will not charge using any charger (pc or wall). The reset function didn't help so it seemed like there was a hardware problem.
I took the phone to a technician who has tried replacing the battery but to no avail.
He told me that if there's a problem with the motherboard then it'd be too expensive to replace and the phone is dead forever.
The frustration is that there are some important photos and videos of my baby daughter that i can't afford to lose so am happy to spend whatever it takes to get this up and running long enough to retrieve my data.
What should I do/try next?
1 Comment
Thanks all for your responses. Will try phone shops for data recovery but I live in Brussels at the moment and find them to be less helpful than in my home town, London, UK.
Puru thanks for the offer which sounds reasonable - I may take you up on that if I can't find anyone trust worth enough in Europe.
by
Add a comment
Chosen Solution
Matt, Mitch Rush is pretty much spot on with the price. To retrieve any information from a dead iPhone will require a NAND flash memory reader as well as the appropriate software with it. The only places that will do this are data recovery places as well as crime labs. One of the things you do want to remember is when you did a last restore on your phone, this may have some of the data you want. The other thing to try is to fix your phone. Take a closer look at the dock connector, make sure you do not have any bend or broken pins, check for corrosion. Check all the fuses on the logic board. You say it does not charge, what happens when you use a charged battery. It might give you enough time to back up your data. Also, check for the power management IC and see if that is burned. If you have a multimeter, you can check the SMD components in the images attached and see if you have continuity. Otherwise apply jumpers as shown.Hope this helps, good luck.
Score 1
2 Comments:
Thanks for this oldturkey. I did a backup shortly before the phone died, but the backups don't save photos do they? If so then perhaps the easiest thing to do is buy a new iphone and load the old backup to the new device...
by
Matt, here is some brief information about the back-up and what it stores :"to recover pictures you don't need any special app.
iTunes copies the files to the backup and uses unique file names
in Windows XP: C: \Documents and Settings\[username]\Application Data\Apple Computer\MobileSync\BackupWindows Vista/7: C: \Users\[username]\AppData\Apple Computer\MobileSync\Backup\ (or something real close)
you will see a folder for every iPhone backup made - pick one
sort the files by size, for the 3gs and older .jpg files will be about 900kb or smaller (3mb camera) and copy them to a temp folder, then rename all of them to *.jpg (in CMD window: ren *.* *.jpg)
change you view to thumbnail and you will see your pictures
" See if this helps. I would also suggest to not work with the original backup files. Copy those before trying to manipulate. That way you still have the original files. Check on here for more info. Hope this helps.
by
Add a comment
Most Helpful Answer
You can get all your photo's without fixing your phone if you take it to someone that is set up to do so, it takes a $1500 piece of hardware that plugs into your charge-data port, it retrieves it and then burns to it to disk, Apple can do it but would surely cost more than most, some phone carriers have them and sometimes do it for free, some phone shop's have them, good luck, If this Answer is helpful please remember to return and mark it Accepted
Score 1
Add a comment
Add your answer
Matt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 515
