My zoom is slow, labored, and frequently gives a "lens error" response
If I use the zoom function on my camera, it usually moves very slowly and makes a chuggish sound. Usually it then beeps, turns off (does not unzoom) and gives a "lens error" message on the screen. The slow movement does not always result in a lens error, and sometimes the zoom moves quickly and then gives an error anyway, but usually it moves badly and then turns off. If I do not use the zoom, the camera does not have any other problems.
I suspect that either the motor is old or it needs to be cleaned, but I do not know how to do this.
Add a comment
Chosen Solution
Megan, it does sound like your lens is giving out on you. I uploaded the service manuals on the device page right here. Check for the heading Service Documents. This should get you to a point where you can clean and degrease your lens with 99% isopropyl alcohol. Hope this helps, good luck
Score 1
Add a comment
Hi Megan, there is an eBay seller that fix Canon S2, S3, S5 and other SX models with lens error.
here is the link in case you need:
Add a comment
Add your answer
Megan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 503
