My laptopt can't boot
when I try to turn on my computer I can see the fan is running and the witness in front of the pc lights. but the pc will turn off after 3-4 seconds and then reboot still remains as it tried to start it but something blocks
saidi.bxl@gmail.com thiks for your help
Also, remove your RAM. Try to restart after you re-connect everything and listen for any POST beep. Which PB laptop is it?
by oldturkey03
Have you checked your power supply? Do you get the proper voltage? Have you check your charging port to make sure it gets power? What model laptop is it?
by oldturkey03
the ram is tested and good power supply is good too the processor tested and certified, every thing work correctly but my laptop dont turn on i think is not porblem with power but i think is the boot bios. but i don't now how to fix it.
by Mourad Saidi
my laptop is packard bell easynote PEW91
by Mourad Saidi
