The Dell Inspiron 1500 is a laptop computer designed for home-entertainment with a narrow border for a wider viewing area.
16 Questions View all
Question Closed
needs drivers for MS ISATAP ADAPTER 8, 9, AND 10.
I have a Dell Inspiron 1505 that shows it has a problem with microsoft ISATAP adapter 8, 9, & 10. It says a new driver might be needed but it can't find one and says it has not been repaired. I have no idea what this means and would appreciate any help.
2 Comments
What OS are you running?
by
I am running windows 7 pro. I went to the device manager and disabled the adapters as you suggested and it seems to have solved the problems. Thank you so much.I had no idea what to do. Your help made it seem so easy that I could not believe it. Again, thank you.
by
Add a comment
1 Answer
Chosen Solution
Otis granger, ""The Microsoft ISATAP device Inter Site Automatic Tunneling Address Protocol is used to help enterprises transition to an IPv6 infrastructure. The ISATAP adapter encapsulates IPv6 packets by using an IPv4 header. This functionality enables the client to transport IPv6 traffic over an IPv4 infrastructure. This approach lets organizations slowly migrate to an IPv6 infrastructure without having to spend excessive time and financial resources to convert to the new infrastructure. " It is just another IP internet layer protocol. You can safely disable it. Many browsers recommend this (disable) since it could slow down, or even causing issue with your internet connection, if the sites you visit cannot support this new layer protocol. To remove IPv6 and all of it's associated devices:
Go into the properties for each network adapter, wired and wireless, and either uncheck the box next to Internet Protocol 6 (TCP/IPv6), that will disable it, or select it and click uninstall, which will remove it off the computer. Then go into device manager and remove any 4to6 adapters, WUN miniport adapters, or ISATAP adapters. Then reboot your computer.
Score 2
2 Comments:
Thank you.
by
you are very welcome. Thank you for accepting my answer, all the best to you:-)
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,950
