Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Why does my iPhone 4 reboot when it's fully charged?
(iPhone 4 GSM, 5.1.1)
Hi there!
As the title says, the iPhone restarts as soon as the battery indicator shows 99-100 percent (when it is plugged). The iPhone would not reboot constantly when it is unplugged. I have tried to change the charging port, and the battery as well.
The battery is just a cheap china-battery from eBay, so it could probably be the cheap batteries that are causing my problem. I just ordered a new OEM battery, so I will let you know if the new battery will fix this.
Or could it be a problem with the motherboard?
- I am so sorry if you think my English grammar is awful
Score -1
Add a comment
1 Answer
Chosen Solution
: ) I would bet your OEM Battery is from China also, this is an interesting problem because it only happens at 99-100 percent charge, some things I would try, your new battery- a hard reset- a software update and, or, a total restore, I would also look into water damage, good luck
Add a comment
Add your answer
Fok Wi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 491
