Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Question Closed
Why won't my phone charge or turn on?
Okay so my battery has been working great and I haven't had any problems with my phone previously. I plug my phone into my charger at night when the battery was nearly empty.
The next morning I woke up and my phone had no battery and would try to turn on but wouldn't. I plugged my phone into the wall and it won't charge past the red screen with the lightning bolt.
I tried using my dad's charger (which I know works) and it didn't do anything. I also tried doing a hard reset (holding the power and home button) that didn't work either.
Next I tried putting my dad's 4s battery in to test, but it was the wrong connector.
I measured the voltage of my battery with a volt meter and it read 3.5 volts out of 3.7...
I also tried plugging the phone into the wall without the battery in it and I noticed that the phone will turn on and come to a screen where you can make an emergency call, but you can't do anything else and will otherwise tell you to connect to itunes.
Next I tried putting the phone in to DFU mode and doing a restore to factory settings and had no luck.
Not sure if this is related to the problem or not, but my dad's phone was plugged into my charger after I had this problem and it had 100 percent battery before I went to bed and in the morning it had only 20 percent.
I have no idea what the problem is...I'm hoping its just the battery, but I won't be able to test that until monday. I've done a lot of researching online for this problem and haven't found any definite results
Add a comment
Most Helpful Answer
sounds like your dock connector needs replacement
iPhone 4 Dock Connector Replacement
Score 1
1 Comment:
yeah but that doesn't make sense, because it'll turn on without the battery plugged in.... if that didn't work it wouldn't be getting any power
by
Add a comment
Its bettry i think u can do one thing on power suply do power you bettry on 4.2 v for 1mint it after that if its works then that was bettry if not let me know
Bilal68181@gmail.com
1 Comment:
it was the battery, thankfully. replaced it for $20
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 6
All Time: 7,660
