Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
24 Questions View all
Question Closed
No display,system seems hang after power ON.
No display getting in both internal and external display device,after powering on.keyboard also not functioning
(tried external keyboard),only two led(Lamp,WIFI)see glowing,cpu&Cooling fan are seems in working condition.pls help to resolve this issue
regards,
ranjith
Add a comment
Most Helpful Answer
Just had the same problem as described above. Retraced my steps (after cleaning insides) and noticed the RAM module wasn't fitted correctly (it should be springy when released from the latches and "jump" out). Made sure it was fitted properly and now all is fine again.
Score 1
Add a comment
It's hard to diagnose this issue without being in front of the system, but, here we go:
If you are not getting video on an external monitor as well the motherboard has failed. More specifically the graphics on the motherboard has malfunctioned. The whole motherboard would need to be replaced for this system to work again. It may be more cost effective to replace the system. You should still be able to pull the hard drive from the system and get data off of it.
The motherboard will probably cost about $125 if you choose to replace it. Sorry to head about your issue.
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,962
