Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
White screen on 3GS, replaced with 3G. Now original screen is dead
I have an iPhone 3GS with the know white screen of death. The problem appeared to be the display cable, because when applying a little pressure on it the display worked.
I received a new LCD and after installing it remained black. Switched back to the original display and it remained black too. The phone is still recognised by iTunes as I was able to do a restore.
I noticed the connectors are a bit different and after searching I noticed I received a display for an iPhone 3G.
My question is, should I order a new display and try again or is there a bigger damage caused by using the wrong display?
Add a comment
Chosen Solution
It's ic display broken
Add a comment
Most Helpful Answer
Nick, you should be okay for as long as you did not bend anything else in the connector. Take a good look at the contacts, make sure they are not bend or broken.
Score 1
3 Comments:
Nothing is broken. My concern is whether something got short-circuited.
by
Most likely not. Biggest issue with that error, and it happens more often than you think, is a broken connector.
by
Hi, u cannot put a 3g display to a 3gs display!!!!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 403
