Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
"Accessory is not supported" Won't charge now?
Charging error appeared on my Iphone 3gs with the Accessory not supported, etc error. I've only used Apple IPhone and Ipad chargers.
Phone ran down and now won't turn on.
Looked at replacing the charging port and/or IC, but folks say that doesn't work.
What to do?
Thanks
Add a comment
1 Answer
Chosen Solution
Danny, this error is most often caused by a faulty dock connector. The first thing you want to try is to clean it with a toothbrush and some isopropyl alcohol. Clean it well. use a few puffs of compressed air to blow out any pocket lint etc. If that does not resolve the issue, replace the dock connector. Of course, make sure that you also try a different cable. At this time, it's a bit early to think about replacing the IC, try the dock connector first. I am sure it might also be time to replace the battery.Hope this helps, good luck.
Score 1
2 Comments:
Thanks oldturkey, I'll try the dock connector!
by
Danny, you are welcome. Let us know how it is going.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 775
